Move to the elocation context to configure ExtremeLocation™.
ExtremeWireless supports integration with ExtremeLocation™ for on-premise controller and ExtremeCloud™ deployments using AP39xx.
The elocation command is accessible from within the location context of the CLI.
The elocation context has the following commands:
The following example moves you to the elocation context of the CLI:
EWC.extremenetworks.com:location#elocation
