Use the push-ap-reporting command to generate a unique report with information about the APs, published through the REST Push Publisher. The push-ap-reporting command is accessible from within the location:publish context.
enable | disable | Enables or disables the push operation on the controller. |
In location-based applications and user traffic analytics, integrating partners often require more detail than simply the location of a MAC address. The AP reporting option allows users to generate a report with details about the APs.
The IoT data is provided when the IoT port is enabled and provisioned. IoT is enabled by default for supported APs.The following example enables the push operation on this controller:
EWC.extremenetworks.com:location:publish# push-ap-reporting enable
