Use the config exit command to exit the RADIUS (Remote Authentication Dial In User Service) server configuration mode. The config exit command is accessible from the wlans:<WLAN-service-name>:auth context of the CLI.
None
Using the config exit command from within the RADIUS server configuration command mode exits the wlans:<WLAN-service-name>:auth RADIUS server configuration context and places you in the wlans:<WLAN-service-name>:auth context.
The following example exits the RADIUS server configuration command mode:
EWC.extremenetworks.com:wlans:cnl-AAA:auth# config exit EWC.extremenetworks.com:wlans:cnl-AAA:auth#
