Use the vsa-egress command to include egress rate control information in the message to the RADIUS (Remote Authentication Dial In User Service) server. The vsa-egress command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run this command, run the apply command to implement the changes.
enable | disable | Specifies to enable or disable the inclusion of egress rate control information in messages to the RADIUS server |
The vsa-egress command is not available when the authentication mode is guestportal. When the authentication mode is disabled, MAC must be enabled for this command to be available. For more information, see mode.
The following example enables the inclusion of egress rate control information in messages to the RADIUS server:
EWC.extremenetworks.com:wlans:test:auth# vsa-egress enable EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show vsa-egress Egress rate control as VSA attribute: enable
