Use the iot-ibeacon-scan-min-rssi command to configure the minimum signal strength required to report a beacon. The iot-ibeacon-scan-min-rssi command is accessible from within the ap:<serial> context of the CLI.
<-100, -10> | This is the signal strength required to include the packet in the BLE report. Valid values: -10 to -100. Default value is -100. Data from beacons with an RSSI that is less than the Min RSSI configured value is filtered out. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin and iot-application ibeacon-scan before issuing this command.
The following example configures the ibeacon-scan-dest-ip address on an AP3912i:
EWC.extremenetworks.com:ap:3912000000000000# iot-ibeacon-scan-min-rssi -30
