Use the auth-timeout command to set the timeout for RADIUS (Remote Authentication Dial In User Service) authentication. The auth-timeout command is accessible from the vnsmode:radius:<named_ RADIUS_server> context of the CLI.
1-360 | Specifies the RADIUS authentication timeout in seconds. |
The following example sets the RADIUS authentication timeout to 10 seconds for the RADIUS server named RAD1:
EWC.extremenetworks.com:vnsmode:radius:RAD1# auth-timeout 10
