Use the filter-mac1 and filter-mac2 commands to set two MAC addresses as a means to filter packets for capture. When specified, only those packets that are received, transmitted, or both to and from the specified MAC addresses are captured.
filter-mac1 MAC Address and filter-mac2 MAC Address | Specifies MAC
address packet capture filters. You can specify two MAC addresses as a means to
filter packets for capture. Note: The filter-mac1 and filter-mac2 filters are mutually exclusive and are applied in a specific
order. The filter-mac1 is applied first. If no match is found, then filter-mac2
is applied and so forth.
After you create the MAC Address filters, use the use-filter-mac1 to use-filter-mac2 commands to apply the filters.
The following example configures the filter-mac1 filter on the wireless AP AP3912i:
EWC.extremenetworks.com:ap-traffic-capture# filter-mac1 B4-C7-99-6C-88-09
