Use the exclude command to exclude an IP address or a range of IP addresses from the DHCP (Dynamic Host Configuration Protocol) Address Range. The exclude command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac, physical, and routed topologies. This command is visible only when mode is set to local. See mode.
A.B.C.D[ A.B.C.D] | Specifies the IP address or range of IP addresses. |
delete | Clears the IP addresses. |
comment comment string | A comment about the excluded IP address or range of IP addresses. |
The following example excludes the address range 10.0.1.10–10.0.1.20:
EWC.extremenetworks.com:topology:test:l3:dhcp# mode local EWC.extremenetworks.com:topology:test:l3:dhcp# exclude 10.0.1.10 10.0.1.20
