Use the wlan command to assign or unassign one or both radios and ports to the specified WLAN service for a specific AP. See Usage for specific port information. The wlan command is accessible from the ap:<serial> context of the CLI.
wlans name | The service you want the AP's radios to be assigned to or removed from. |
radio1 | radio2 | both | Specifies the radios to assign to the WLAN service. Use both to assign both radios at one time. |
no-radio1 | no-radio2 | none | Specifies the radios to unassign to the WLAN service. Use none to remove all assignments at one time. |
p1 | p2 | p3 | Specifies
the client ports on the AP3912 to assign to the WLAN service. Note: The camera on the AP3916 always
connects to p1.
no-p1 | no-p2 | no-p3 | Specifies the client ports on the AP3912 to unassign to the WLAN service. |
iot | Specifies the IoT port on the AP391x to assign to the WLAN service. |
no-iot | Specifies the IoT port on the AP391x to unassign to the WLAN service. |
This command is only available when the WLAN service type is STD.
EWC.extremenetworks.com:ap:0500008043050355# wlan CNL-91-0-1 radio2 EWC.extremenetworks.com:ap:0500008043050355# show host_name AP3935-0500008043050355 name AP3935 internal desc usedhcp poll_timeout 15 client_session no persistent no bcast_disassoc no vlanid country Germany led-mode normal wlan CNL-91-0-1 radio2
EWC.extremenetworks.com:ap:0500008043050355# wlan CNL-91-0-1 radio2 p3
EWC.extremenetworks.com:ap:1111111111139161# wlan v1WLAN p1
EWC.extremenetworks.com:ap:1111111111113912# wlan Service1 both p1 p2 p3 iot
