show log
Use the show log command to display logs and reports for the Wireless Appliance.
show log log_name | first | last | number
Parameters
log_name The log that you want to view:
  • ospf-neighbor
  • ospf-linkstate
  • dhcp
  • ntp
  • ac (critical|major|minor|info|all)
  • ap <ap_serial> (critical|major|minor|info|all)
  • mu_access.log
  • upgradeLog.txt
  • auditRecords.log
  • upgrade.log
  • configChanges.log
  • login.log
  • station
first Indicates that the first records in the log will be displayed.
last Indicates that the last records in the log will be displayed.
number Specifies the number of logs to display from the file.
The following example displays the first two records from the auditRecords log file:
EWC.extremenetworks.com# show log auditRecords.log first 2
 5516324453019803260admin                         CLI_controller                general                       key configuration changed: activate TRDKNAM-NCF47ABS-I1BVRP9U-SGDKVBFR-NFBQ6ZJQ,
 5516324457314024504admin                         CLI_system_management         general                       downloading import file from server 192.168.3.108
The following example displays the last five DHCP (Dynamic Host Configuration Protocol) log messages:
EWC.extremenetworks.com# show log dhcp last 5
Timestamp          DHCP Message
Sep 13 20:33:14    dhcpd: DHCPACK to 172.21.177.21 (00:11:95:ec:a7:c0) via esa9
Sep 13 20:34:53    dhcpd: DHCPINFORM from 172.21.177.21 via esa9
Sep 13 20:34:53    dhcpd: DHCPACK to 172.21.177.21 (00:11:95:ec:a7:c0) via esa9
Sep 13 20:34:56    dhcpd: DHCPINFORM from 172.21.177.21 via esa9
Sep 13 20:34:56    dhcpd: DHCPACK to 172.21.177.21 (00:11:95:ec:a7:c0) via esa9
The following example displays log entries from OSPF (Open Shortest Path First) neighbors:
EWC.extremenetworks.com# show log ospf-neighbor
Neighbor RouterID    Router Priority    State      IP           Interface
192.168.12.7         1                  Full/DR    10.91.0.2    esa0:10.91.0.1
The following example displays the log entries for the OSPF linkstate database:
EWC.extremenetworks.com# show log ospf-linkstate
Router LSA (Type 1):
Link ID          Advertising Router    Age     Sequence No    Checksum    Link Count
192.168.4.202    192.168.4.202         1460    0x80000085     0x8f18      3
The following example displays the log entries for upgradeLog.txt:
EWC.extremenetworks.com# show log upgradeLog.txt
OS-7_31_0-7
Wed Mar 19 14:21:48 EDT 2008 OS-5_1_8-1
Installing rpm of version V5R1.10034.0 on Wed Mar 19 14:21:53 EDT 2008
Tue Mar 10 12:39:04 EDT 2009 OS-5_3_17-1
Installing rpm of version V5R3.10034.0 on Tue Mar 10 12:39:11 EDT 2009
Mon Jun 1 10:52:53 EDT 2009 OS-6_0_19-1
Installing rpm of version V6R0.10019.0 on Mon Jun  1 10:52:59 EDT 2009
Thu Aug 20 14:47:27 EDT 2009 OS-6_1_8-1
Installing rpm of version V6R1.10029.0 on Thu Aug 20 14:47:39 EDT 2009
Installing rpm of version V6R1.10602.0 on Mon Sep 13 05:11:30 EDT 2010
Installing rpm of version 07.41.01.0122T on Mon Sep 13 05:31:02 EDT 2010
The following example displays the log entries for upgrade.log:
EWC.extremenetworks.com# show log upgrade.log
Sep 13 05:30:47 EDT 2010 From: V6R1.10602.0 To: 07.41.01.0122T
Sep 13 05:30:47 EDT 2010 C25 Upgrading From Release 6_1
Sep 13 05:35:05 EDT 2010 Successfully imported license
Sep 13 05:35:21 EDT 2010 Successfully Restored the Configuration
Sep 13 05:35:22 EDT 2010 Successfully Performed Netsight Import
The following example displays the log entries for configChanges.log:
EWC.extremenetworks.com# show log configChanges.log
CLI Import/EWC.extremenetworks.com: start: Tue Sep 14 00:27:57 2010
CLI Import/EWC.extremenetworks.com: end: Tue Sep 14 00:28:16 2010
The following example displays the station log entries:
EWC.extremenetworks.com# show log station
Msg: 06/14/13 06:58:34  EventType[De-registration]      MAC[00:24:D7:23:89:4C]  BSSID[00:0F:BB:09:EC:E9]        Details: VNS[CNL-91-0-6] Cause[Idle timeout]
Msg: 06/14/13 05:49:48  EventType[State Change] MAC[00:24:D7:23:89:4C]  IP[172.21.176.54]       BSSID[00:0F:BB:09:EC:E9]        SSID[CNL-91-0-6-ssid]   User[tester1]
Msg: 06/14/13 05:49:45  EventType[Authentication]       MAC[00:24:D7:23:89:4C]  AP[0500006072051204]    BSSID[00:0F:BB:09:EC:E9]        SSID[CNL-91-0-6-ssid]User[tester1]    Details: VNS[CNL-91-0-6] AppliedRole[CNL-91-0-6-default]
Msg: 06/14/13 05:49:45  EventType[State Change] MAC[00:24:D7:23:89:4C]  BSSID[00:0F:BB:09:EC:E9]        Details: VNS[CNL-91-0-6] Auth[valid]
Msg: 06/14/13 05:49:44  EventType[State Change] MAC[00:24:D7:23:89:4C]  BSSID[00:0F:BB:09:EC:E9]        Details: VNS[CNL-91-0-6] Auth[invalid]
Msg: 06/14/13 05:49:44  EventType[MBA Accepted] MAC[00:24:D7:23:89:4C]  AP[0500006072051204]    BSSID[00:0F:BB:09:EC:E9]        SSID[CNL-91-0-6-ssid]   Details: VNS[CNL-91-0-6] AppliedRole[CNL-91-0-6-default]
Msg: 06/14/13 05:49:44  EventType[Registration] MAC[00:24:D7:23:89:4C]  AP[0500006072051204]    BSSID[00:0F:BB:09:EC:E9]        SSID[CNL-91-0-6-ssid]   Details: Radio[2]
