Use the lease-max command to set the maximum time limit, in seconds, that an IP address would be assigned by the DHCP (Dynamic Host Configuration Protocol) server to a wireless device. The lease-max command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac, physical, and routed topologies. This command is visible only when mode is set to local. See mode.
After you run the lease-max command, run the apply command to implement the changes.
int | Specifies the time limit in seconds. |
The following example sets the maximum time to keep a DHCP-ed IP address to 2592000 seconds:
EWC.extremenetworks.com:topology:routed2:l3:dhcp# mode local EWC.extremenetworks.com:topology:routed2:l3:dhcp# lease-max 2592000 EWC.extremenetworks.com:topology:routed2:l3:dhcp# apply
