Use the create command to create an NAC server configuration. The NAC server accepts DHCP (Dynamic Host Configuration Protocol) messages. The create command is accessible from the vnsmode:nac context of the CLI. After you create an NAC server configuration, you can further configure it by entering the vnsmode:nac:<named-NAC-server> context. See radius.
name | Specifies the name of the NAC server |
A.B.C.D | Specifies the IP address of the NAC server |
Up to three NAC server configurations can be created.
The following example creates and then displays the details of an NAC server configuration named test-nac-server with an IP address of 10.10.10.11:
EWC.extremenetworks.com:vnsmode:nac# create test-nac-server 10.10.10.11 EWC.extremenetworks.com:vnsmode:nac# test-nac-server EWC.extremenetworks.com:vnsmode:nac:test-nac-server# show
