Use the show command from the wlans context to display WLAN (Wireless Local Area Network) service configuration information.
WLANS-name | Specifies to display information about the specific WLAN service |
The Radio Mode field displays the 802.11 modulations that the AP‘s radios are configured to use.
EWC.extremenetworks.com:wlans# show Name Service Type Enabled SSID Privacy Auth Mode Radio Mode osu std enabled osu none disabled off hs std enabled hs wpa 8021x off std std enabled std none internal off
EWC.extremenetworks.com:wlans# show hs Service type: std Hotspot type: enabled Name: hs Enable/disable WLAN Service: enable Remotable: disable Inter-WLAN Service Roaming: enable Associated WLANs: hs Egress Filtering: disable Radio1 Radio2 AP Name 3705i 3805i ap3935i 3965 3805e ap3805i3 3825i1 ap3935e SSID: hs Default topology: Pre-authentication timeout(minutes): 5 Post-authentication timeout(minutes): 30 Session timeout(minutes): 0 Enable/disable block MU to MU traffic: disable Default CoS: No CoS Default Traffic Mirror: prohibited Enable/disable Netflow support: disable Unauthenticated Behavior: discard-unauth-traffic Radio Mode: off
