Use the protocol command to configure the authentication protocol to be used with the RADIUS (Remote Authentication Dial In User Service) server being configured. The protocol command is accessible from the wlans:<WLAN-service-name>:auth context of the CLI.
After you run the protocol command, run the apply command to implement the changes.
CHAP | Configures the Challenge Handshake Authentication Protocol as the authentication protocol |
PAP | Configures the Password Authentication Protocol as the authentication protocol |
MS-CHAP | Configures the Windows specific version of CHAP as the authentication protocol |
MS-CHAP2 | Configures the Windows specific version (Version 2) of CHAP as the authentication protocol |
You must be in RADIUS server configuration mode for the protocol command to be available. Use the config command to enter RADIUS server configuration mode. For more information, see config.
The following example configures the CHAP protocol as the authentication protocol for this RADIUS server:
EWC.extremenetworks.com:wlans:cnl-AAA:auth# protocol CHAP EWC.extremenetworks.com:wlans:cnl-AAA:auth# apply
