Use the whitelist command to configure a whitelist of node sensors for the Thread Network. The whitelist command is accessible from the whitelist-iot context of the CLI.
add | Add sensor node to the whitelist. |
delete | Delete sensor node from the whitelist. |
<eui> | Extended Unique Identifier for each sensor node, determined by the sensor manufacturer. |
<password> | Pre-shared password. Sensor passwords are created when the sensor is commissioned, outside of ExtremeWireless. The default password is THREAD. |
If the whitelist is not configured, all sensors with password THREAD are accepted into the network.The following example adds a sensor node to an IoT whitelist.
EWC.extremenetworks.com:ap:whitelist-iot# whitelist add F7604280EB000000 extreme
The following example deletes a sensor node from an IoT whitelist.
EWC.extremenetworks.com:ap:whitelist-iot# whitelist delete F7604280EB000000 abcd
