lpm-override
Use the lpm-override command to configure Low Power Mode Override.
lpm-override enable | disable
Parameters
enable |
Enable Low Power Mode Override. |
disable |
Disable Low Power Mode Override. The default configuration
for the 39xx APs is disabled. |
Usage
Enable lpm-override to have AP
always
operate in 4x4 mode regardless of what was negotiated with the Switch
PoE (Power over Ethernet). When this option is disabled, the AP operates in 2x2 or 4x4 depending on
what was negotiated with the Switch PoE using the 2-event classification.
- AP sends Power Status element with "Power Mode" set to 0 when "Low
Power Mode Override" is enabled.
- AP sends Critical Log "entering Low Power mode" only if negotiated
.af with Switch PoE and "Low Power Mode Override" is disabled. Otherwise, Critical Log
is not sent.
- Controller "Network Health" shows only APs that have "Power Mode"
bit in the Power Status set to 1. The default configuration for the 39xx APs is
disabled.
EWC.extremenetworks.com:ap# lpm-override enable
