Use the create command to create, insert, or append a new filter rule into an AP or AC filter list for a <named-role>. The create command is accessible from within the vnsmode:<default-role>:acfilters and vnsmode:<default-role>:apfilters contexts.
Use the following syntax to specify a position value and protocol for a filter rule in the filter list. No application is specified.
Use the following syntax to specify an application in the filter rule definition for an AP or AC filter list.
Use the following syntax to specify a custom application in the L7 layer of the filter rule definition for an AP or AC filter list.
pos | Specifies a position value for this filter in the filter list. Valid values are from 0 - 255. |
proto protocol | Specifies the protocol for this filter rule by number
or name. Valid number values are from 0 - 255. Valid name values are:
eth ether-type | ether-type: 4 hex digits from 0001~FFFF, or any. The following well known values are converted into hex values, IPv4,ARP,RARP,DECnet Phase IV,AppleTalk (EtherTalk), AppleTalk Address Resolution Protocol (AARP), Novell IPX (alt), Novell, Profinet, and IPv6. Note: IPv6 is supported for
Layer 2 bridging for both B@AC and B@AP topologies.
mac MAC address | MAC address: MAC or CIDR address, or any. |
ipaddress/mask
IPv6 interface-subnet interface-ip any |
The IP address and/or mask for this filter rule. The IP address is in IPv6 format. Use the IP address and mask configured for the associated topology for this filter rule. Use the IP address of the associated topology for this filter rule. Use any IP address or mask for this filter rule. |
port port [ port] | Specifies a TCP or UDP port or port range to which this filter rule will be applied. The first port value specifies either the port or the start of a port range. The second port value optionally specifies the end of a range. This parameter is valid only when either TCP or UDP is the specified protocol. Valid port values are from 0 - 65535. |
type-code type [ type] | Specifies an ICMP type code or range of ICMP type codes. The first type value specifies either the ICMP type code or the start of a type code range. The second type value optionally specifies the end of a type code range. This parameter is valid only when ICMP is the specified protocol. Valid type values are from 0 - 255. |
in (none |src | dst | both) | Specifies the direction of packet flow. — in
specifies a packet flow from the AP to the AC. none specifies that the in direction will not be used as matching criteria in the filter rule. dst specifies that the IP address for this filter rule is the destination of the packet flow. src specifies that the IP address for this filter rule is the source of the packet flow. both specifies that the IP address for this filter rule can be either source or destination. |
out (none | src | dst | both) | Specifies the direction of packet flow. — out
specifies a packet flow from the AC to the AP. none specifies that the out direction will not be used as matching criteria in the filter rule. dst specifies that the IP address for this filter rule is the destination of the packet flow. src specifies that the IP address for this filter rule is the source of the packet flow. both specifies that the IP address for this filter rule can be either source or destination. |
allow | deny | none | contain2vlan vlan-id | redirect | Specifies whether packets are allowed or denied (or ignored), or put in the containment VLAN (Virtual LAN) (you must specify the VLAN by its ID), or redirected when meeting the criteria specified in the filter rule. |
priority (0-7 | none) | Specifies the packet priority. Valid values are 0-7; the highest priority is 7. Specifying none means priority level will not be used as matching criteria in this CoS (Class of Service). |
tos-dscp (tos-dscp value/mask value | none) | Specifies the type of service in the filter rule. Valid values are 0-FF for ToS/DSCP and FF|FE|FC|F8|F0|E0|C0|80 for mask. Specifying none means tos/dscp value is not used as matching criteria in the filter rule. |
cos (named-cos| none) | Specifies the class of service in the filter rule. The named-cos must already be created by the create command in the cos context. Specifying none means CoS is not used as matching criteria in the filter rule. |
traffic-mirror | Specifies
the behavior applied to a traffic mirror: none specifies the filter rule is not configured for traffic mirror. enable specifies that the traffic rule is enabled for traffic mirror prohibited specifies that the traffic rule is prohibited for traffic mirror. |
application app_id | Specifies an application on the filter rule definition. |
app-signature app_id | Specifies a custom application on the L7 layer of the filter definition rule. |
group group | Specifies the pre-defined group, of which the (L7) custom application is a member. |
name app name | Specifies the application name for the (L7) custom application. |
hostname app name | Indicates that the custom application type is hostname. The (L7) custom application authenticates based on a user defined IP/subnet parameter in the Layer 3 configuration. This configuration allows mobile clients to authenticate using credentials from a specific host. For more information, see the ExtremeWireless User Guide. |
If the specified rule position already contains a filter rule, specifying a rule using this command inserts a rule in the specified position in the list and re-sequences all rules below this filter down by one position. Use the create command to insert or append a rule at the specified position.
The following example shows the default filter rules applied to the Auth role:
EWC.extremenetworks.com:vnsmode:Auth# create p6 EWC.extremenetworks.com:vnsmode:Auth# show p6 acfilter Enable AP filtering: disable filter 1 (default) proto none 0.0.0.0 all_ports in dst out none allow filter 2 (default) proto none 0.0.0.0 all_ports in none out src allow
The following example creates a (basic mode) filter rule 1 that allows UDP traffic in both directions from IP address 192.168.10.0/24 for ports 10 through 2000:
EWC.extremenetworks.com:vnsmode:Auth:acfilters# create 1 proto udp 192.168.10.0/24 port 10 2000 in dst out src allow EWC.extremenetworks.com:vnsmode:Auth:acfilters# apply EWC.extremenetworks.com:vnsmode:Auth:acfilters# show Enable AP filtering: disable filter 1 proto udp 192.168.10.0 255.255.255.0 port 10 2000 in dst out src allow filter 2 (default) proto none 0.0.0.0 all_ports in dst out none allow filter 3 (default) proto none 0.0.0.0 all_ports in none out src allow
The following example creates a filter rule 1 that is inserted into the rule list at position 1 resequencing the current rule 1. This filter rule allows TCP traffic in both directions from IP address 192.168.0.0/16 for ports 10 through 2000:
EWC.extremenetworks.com:vnsmode:Auth:acfilters# create 1 proto tcp 192.168.0.0/16 port 10 2000 in dst out src allow EWC.extremenetworks.com:vnsmode:Auth:acfilters# show Enable AP filtering: disable filter 1 proto tcp 192.168.0.0 255.255.0.0 port 10 2000 in dst out src allow filter 2 proto udp 192.168.10.0 255.255.255.0 port 10 2000 in dst out src allow filter 3 (default) proto none 0.0.0.0 all_ports in dst out none allow filter 4 (default) proto none 0.0.0.0 all_ports in none out src allow
The following example creates a filter rule for ToS-DSCP B8/FF and CoS Best Effort (note quotes around the named CoS because of the space):
EWC.extremenetworks.com:vnsmode:Auth:acfilters# create proto udp 192.168.0.0/32 in dst out src none priority none tos-dscp B8/FF cos “Best Effort”
