Use the iot-ibeacon-minor command to configure the ibeacon Minor — Identifies an individual beacon. Used to more precisely pinpoint beacon location. This value complements the UUID and Major values to provide more granular identification of a specific location, such as a particular shelf, door-way, or item. Valid values are 0 to 65635. The iot-ibeacon-minor command is accessible from within the ap:<serial> context of the CLI.
<0, 65535> | A 2-byte string that identifies an individual beacon. Enter a value between 0 and 65535. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin before issuing this command.
The following example sets the iBeacon Minor on wireless AP3916ic.
EWC.extremenetworks.com:ap:1254Y-3211230000#iot-ibeacon-minor 88
