Use the iot-thread-gateway-channel command to configure the IoT Thread Gateway Channel for the AP. The iot-thread-gateway-channel command is accessible from within the ap:<serial> context of the CLI.
<11, 26> | AP Channel Number between 11 and 26. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin before issuing this command and specify the iot-application as Thread Gateway.
The following example sets the iot-thread-gateway-channel on an AP3915.
EWC.extremenetworks.com:ap:1111111111113915# iot-thread-gateway-channel 25
