Use the acct-port command to set the port for RADIUS (Remote Authentication Dial In User Service) accounting. The acct-port command is accessible from the vnsmode:radius:<named_RADIUS _server> context of the CLI.
If you do not change the port with this command, the default port 1813 is used.
0-65535 | Specifies the RADIUS accounting port |
The following example sets the RADIUS accounting port to 1646 for the RADIUS server named RAD1:
EWC.extremenetworks.com:vnsmode:radius:RAD1# acct-port 1646
