Use the auth-prio command to set the priority for RADIUS (Remote Authentication Dial In User Service) authentication. The auth-prio command is accessible from the vnsmode:radius:<named_ RADIUS_server> context of the CLI.
integer | Specifies the RADIUS authentication priority. Possible values can be any integer 0 or greater. |
The following example sets the RADIUS authentication priority to 5 for the RADIUS server named RAD1:
EWC.extremenetworks.com:vnsmode:radius:RAD1# auth-prio 5
