Use the service-type-login command to enable or disable setting the service type attribute to login. The service-type-login command is accessible from the vnsmode:radius context of the CLI.
enable | Enables the defer accounting start feature. |
disable | Disables the defer accounting start feature. |
This command allows you to optionally set the RADIUS (Remote Authentication Dial In User Service) Access-Request and Accounting-Request Service-Type attribute to Login. The default service type is Framed. Setting the Service-Type to Login conflicts with the controller administrative RADIUS login since the administrative login also sets the Service-Type to Login. If administrative RADIUS login is enabled, Service-Type set to Login will be blocked and vice versa.
The following example enables service type to login:
EWC.extremenetworks.com:vnsmode:radius# service-type-login enable
