Use the vsa-ap command to include AP Identification in the message to the RADIUS (Remote Authentication Dial In User Service) server. The vsa-ap command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run the vsa-ap command, run the apply command to implement the changes.
enable | disable | Enables or disables the inclusion of AP Identification information in messages to the RADIUS server. |
The vsa-ap command is not available when the authentication mode is guestportal. When the authentication mode is disabled, MAC must be enabled for this command to be available. For more information, see mode.
The following example enables the inclusion of AP Identification information in messages to the RADIUS server:
EWC.extremenetworks.com:wlans:test:auth# vsa-ap enable EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show vsa-ap AP as VSA attribute: enable
