Use the authset command to set authentication server information. The authset command is available from the login:auth context.
server_name | Specifies a valid RADIUS (Remote Authentication Dial In User Service) server name |
port | Specifies the RADIUS server port |
retry_value | Specifies the number of times to attempt to access the RADIUS server |
time_out | Specifies the time in seconds to wait for a response from the RADIUS server before trying again |
NAS_IP | Specifies the NAS IP address |
nas_string | Specifies the Network Access Server (NAS) Identifier |
PAP | CHAP | MS-CHAP | MS-CHAP2 | Specifies the Authentication Protocol |
The following example specifies the authentication server information:
EWC.extremenetworks.com:login:auth# authset Radius 1812 3 5 192.168.4.112 NAS MS-CHAP
