Use the sync command in the vnsmode:<named-VNS> context to enable or disable automatic synchronization of this VNS (Virtual Networks Service) across paired controllers. Refer to the Wireless User Guide for more information about synchronization of VNSs.
After you run the sync command, run the apply command to implement the changes.
enable | Enables automatic synchronization of this VNS across paired controllers. |
disable | Disables automatic synchronization of this VNS. |
This example enables automatic synchronization of the current VNS, named VNS1, across paired controllers:
EWC.extremenetworks.com:vnsmode:VNS1# sync enable EWC.extremenetworks.com:vnsmode:VNS1# apply
