AP3935e Ports
Use the following port commands for the AP 3935e to select an antenna port. These commands are accessible from the <serial> context of the CLI. For AP models that support the Professional Install feature, these commands are accessible from the ap:<serial>:professional_antenna# context. To display a list of the available antenna models, enter a command without arguments.
  • port1-radio1 <antenna_model>
  • port1-radio2 <antenna_model>
  • port2-radio1 <antenna_model>
  • port2-radio2 <antenna_model>
  • port3-radio1 <antenna_model>
  • port3-radio2 <antenna_model>
  • port4-radio1 <antenna_model>
  • port4-radio2 <antenna_model>
port1-radio1 antenna_model
Parameters
antenna_model Model name of an antenna supported by the Wireless AP.
This example lists the valid antenna models that can be entered with this command, then executes the command with an appropriate model number:
EWC.extremenetworks.com ap:3935e000R100on00:professional_antenna# port1-radio1
Error : There is no selected antenna model.
Usage: port1-radio1 <antenna_model>
antenna_model:
<list of valid antenna models>
WS-ANT-5DIP-4 Dipole
WS-AI-DQ05120 5dBi 120deg Sector
WS-AI-DQ04360 4dBi Omni
WS-AI-DE10055 10/6dbi 55deg Sector
WS-AI-DE07025 6.5/5dbi 25deg Sector
WS-AI-5Q05025 5.5dbi 25deg Sector
WS-AI-5Q04060 5dbi 60deg Sector
No Antenna
EWC.extremenetworks.comap:3935e000R100on00:professional_antenna# port1-radio1
WS-ANT-5DIP-4
This example removes a configured port1 radio1 antenna:
EWC.extremenetworks.com:ap:3935e000R100on00:professional_antenna# port1-radio1  No Antenna
