Use the show capture-info command to view captured packet information after you have started and stopped the packet capture.
None
Before you can use show capture-info, you must configure the packet capture and start and stop the capture.
The following example displays packet capture information on a wireless AP:
EWC.extremenetworks.com:ap-traffic-capture# ap 1548Y-1007900000 EWC.extremenetworks.com:ap-traffic-capture# capture-location wired-direction both include-clients enable EWC.extremenetworks.com:ap-traffic-capture# max-packet 5000 EWC.extremenetworks.com:ap-traffic-capture# start EWC.extremenetworks.com:ap-traffic-capture# stop EWC.extremenetworks.com:ap-traffic-capture# filter-mac1 11:22:33:44:55:66 EWC.extremenetworks.com:ap-traffic-capture# filter-ip1 192.168.2.1 EWC.extremenetworks.com:ap-traffic-capture# protocol icmp EWC.extremenetworks.com:ap-traffic-capture# port 8080 EWC.extremenetworks.com:ap-traffic-capture# show capture-info AP Packet Capture Information: Capture file created: 2017-09-07 16:11:08 For AP: 1548Y-1007900000 Size: 5136Bytes
