Use the group-key-ps command to enable or disable the group key power save retry. The group-key-ps command is available only if the mode command is set to wpa-psk. The group-key-ps command is accessible from the wlan:<WLAN-service-name>:priv context of the CLI when the WLAN (Wireless Local Area Network) service type is STD.
enable | Specify to enable the group key power save retry. |
disable | Specify to disable the group key power save retry. |
The following example enable the group key power save retry on the WLAN CNL-208-0:
EWC.extremenetworks.com:wlans:CNL-208-0:priv# group-key-ps enable
