Use the primary command to set the RADIUS (Remote Authentication Dial In User Service) server as the primary server for authentication. Use the no form of the command to disable it. The primary command is available from the login:auth context.
server_name | Specifies the name of the server |
The following example sets the primary authentication server:
EWC.extremenetworks.com:login:auth# primary FreeRadius70
