Use the iot-admin command to enable or disable the IoT functionality for the supported APs. The iot-admin command is accessible from within the ap:<serial> context of the CLI.
enable | Activates the Internet of Things (IoT) functionality for supported APs. |
disable | Deactivates the Internet of Things (IoT) functionality for supported APs. |
The following APs offer integrated BLE/802.15.4 radios: AP3912 , AP3915, AP3916ic, AP3917.
The following example enables the IoT functionality on an AP3916ic.
EWC.extremenetworks.com:ap:0500008043050555# iot-admin enable
