Use the iot-thread-gateway-master-key command to configure the IoT Thread Gateway Master Key for the AP. The iot-thread-gateway-master-key command is accessible from within the ap:<serial> context of the CLI.
<string> | Indicates the Network Master Key used to encrypt communication between nodes in a Thread Network. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin before issuing this command and specify the iot-application as Thread Gateway.
The following example sets the iot-thread-gateway-master-key on an AP3915.
EWC.extremenetworks.com:ap:1111111111113915# iot-thread-gateway-master-key 1118E844415FFE08794E0713948763B8
