Use the radius-accounting command to enable or disable RADIUS (Remote Authentication Dial In User Service) accounting. The radius-accounting command is accessible from the vnsmode:radius context of the CLI.
enable | Enables RADIUS accounting. |
disable | Disables RADIUS accounting. |
The following example enables RADIUS accounting:
EWC.extremenetworks.com:vnsmode:radius# radius-accounting enable
