Use the iot-eddystone-url command to configure the embedded url within the eddystone-url-beacon.
The iot-eddystone-url command is accessible from within the ap:<serial> context of the CLI.
https url | The URL
that is included with the Eddystone-url beacon. The URL is limited to 17 characters. The 17 characters does not include the protocol, but it does include the domain name. A secure protocol (HTTPS address) is required. The URL is compressed, effectively allowing more than a 17-character input. See https://github.com/google/eddystone/tree/master/eddystone-url for the Eddystone-url compression rules to more accurately judge the length of your URL. If necessary, also find third-party URL Shortening Services available on the internet. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin before issuing this command.
The following example sets the iot-eddystone-url on the AP3915:
EWC.extremenetworks.com:ap:1254Y-3211230000#iot-eddystone-url https://www.abcdefg.com
