Use the iot-interval command to configure the iot-interval — The advertising interval for the beacon application. Valid values are: Min (100ms) and Max (10240ms). The default value is Min (100ms). The iot-interval command is accessible from within the ap:<serial> context of the CLI.
| <100, 10240> | Advertising interval for the iBeacon application. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin before issuing this command.
The following example sets the iBeacon advertising interval on an AP3916ic to the maximum value.
EWC.extremenetworks.com:ap:1254Y-3211230000#iot-interval 10240
Print
this page
Email this topic
Feedback
