Excessive packet capture degrades network performance. When enabling packet capture on all APs, specify at least one MAC address filter to avoid performance degradation.use-filter-mac1 enable | disable and use-filter-mac2 enable | disable | Use the
use-filter-mac1 and use-filter-mac2
parameters to enable or disable the MAC Address filters.
The following example applies the filter-mac1 filter on the wireless AP AP3912i:
EWC.extremenetworks.com:ap-traffic-capture# use-filter-mac1 enable
