Use the radtest command to test the RADIUS (Remote Authentication Dial In User Service) server‘s connectivity and configuration. RADIUS servers with captive portal (CP) and EAP authentication can be tested for connectivity.
vns_name | Specifies the VNS (Virtual Networks Service) assignment ID of the virtual interface (WLAN (Wireless Local Area Network) Service) configured on the controller. |
username | Specifies a username. |
password | Specifies a password. |
The following example tests the radius server on CNL-7-CP:
EWC.extremenetworks.com# radtest CNL-7-CP chap106 xyz789 Sending Captive portal authentication request to Radius Server for user chap106, with password xyz789, on vns_name CNL-7-CP. Please wait while all configured Radius Servers on this VNS are attempted as needed ... Test Completed. The Radius Server has successfully authenticated the user chap106 with password xyz789 and VNS CNL-7-CP.
