Use the server command to select a RADIUS (Remote Authentication Dial In User Service) server. The server command is available from the login:auth context.
# | Specifies the index number of the RADIUS server to be used |
name | Specifies the name of the RADIUS server to be used |
The following example selects a radius server by name:
EWC.extremenetworks.com:login:auth# server rad2
