Use the downlink command to manage downlink policer action for this WLANS. The downlink command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the downlink command, run the apply command to implement the changes.
downgrade | Specifies that the transmission‘s data packets are forced to be downgraded to the next priority when a TSPEC violation is discovered. |
drop | Specifies that the transmission‘s data packets are forced to be dropped when a TSPEC violation is discovered. |
do-nothing | Specifies that the TSPEC violations are allowed to continue when they are discovered. Data transmissions will continue and no action is taken against the violating transmissions. |
The following example defines the QoS (Quality of Service) downlink policy to drop the transmission‘s data packets when a TSPEC violation is discovered:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# downlink drop EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply
