Use the radius-mac-format command to set the MAC address format to be exchanged with the RADIUS (Remote Authentication Dial In User Service) server. The radius-mac-format command is accessible from the vnsmode:radius context of the CLI.
After you run the radius-mac-format command, run the apply command to implement the changes.
1 | Specifies a MAC address format of XXXXXXXXXXXX for use with the RADIUS server |
2 | Specifies a MAC address format of XX:XX:XX:XX:XX:XX for use with the RADIUS server |
3 | Specifies a MAC address format of XX-XX-XX-XX-XX-XX for use with the RADIUS server |
4 | Specifies a MAC address format of XXXX.XXXX.XXXX for use with the RADIUS server |
5 | Specifies a MAC address format of XXXXXX-XXXXXX for use with the RADIUS server |
6 | Specifies a MAC address format of XX XX XX XX XX XX for use with the RADIUS server |
7 | Specifies a MAC address format of xxxxxxxxxxxx for use with the RADIUS server |
8 | Specifies a MAC address format of xx:xx:xx:xx:xx:xx for use with the RADIUS server |
9 | Specifies a MAC address format of xx-xx-xx-xx-xx-xx for use with the RADIUS server |
10 | Specifies a MAC address format of xxxx.xxxx.xxxx for use with the RADIUS server |
11 | Specifies a MAC address format of xxxxxx-xxxxxx for use with the RADIUS server |
12 | Specifies a MAC address format of xx xx xx xx xx xx for use with the RADIUS server |
The following example sets the RADIUS MAC address format to XX:XX:XX:XX:XX:XX:
EWC.extremenetworks.com:vnsmode:radius# radius-mac-format 2
