Use the tos-dscp-mask command to configure a ToS/DSCP marking value and mask, in hexadecimal. If WLAN (Wireless Local Area Network) marking is enabled, the ToS or DSCP value (only one or the other is present in the received packet) is taken from the WLAN. Enter the value/mask combination you want used.
The tos-dscp-mask command is accessible from within the cos:<named-cos> context.
tos-dscp | Valid values, in hexadecimal., for ToS/DSCP are 0-FF. |
mask | Valid values, in hexadecimal., for mask are 0-FF. |
none | ToS /DSCP values are not used. |
The slash (/) is a literal separator of tos/dscp and mask values.
The following example configures a ToS-DSCP marking value (1E) and a mask value of FF:
EWC.extremenetworks.com:cos:my-cos# tos-dscp-mask 1E/FF
