Use the config command to configure a RADIUS (Remote Authentication Dial In User Service) server as the local authentication server for APs assigned to this site. The config command is accessible from the site:<named-site> context.
radius name | Specifies the RADIUS server to be assigned to this site, and enters config mode for the named server. |
prot CHAP|PAP|MS-CHAP|MS-CHAP2 | Specifies the authentication protocol to be used with this RADIUS server. Values are CHAP, PAP, MS-CHAP, and MS-CHAP2. |
exit | Exits config mode. |
Enter config radius name to enter config mode for that server. Enter config exit to exit config mode.
The following example assigns RADIUS server R-1 to site1, and enters config mode for R-1:
EWC.extremenetworks.com:site:site1# config R-1
