Use the dns command in the host-attributes:dns context to configure DNS servers for the controller. You can configure up to three DNS servers to resolve RADIUS (Remote Authentication Dial In User Service) server host names to their corresponding IP addresses. Use the no form of the command to remove a DNS server configuration.
After you have run the dns command, run the apply command to implement the changes.
1-3 | Specifies the position of the DNS server in the DNS servers list. |
ip address | Specifies the IP address of the DNS server. The IP address can be either IPv4 A.B.C.D or IPv6 A:B:C:D:E:F:G:H format. |
The following example defines a DNS server, with a 192.1.1.3 IP address, as the first DNS server:
EWC.extremenetworks.com:host-attributes:dns# dns 1 192.1.1.3
