Use the legacy command to enable or disable the legacy solution, which gives all packets on the VNS (Virtual Networks Service) high priority. The legacy command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the legacy command, run the apply command to implement the changes.
enable | disable | Enables or disables the legacy solution. |
Legacy Wireless QoS (Quality of Service) support cannot be re-enabled once it has been disabled.The following example enables the legacy solution for the VNS:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# legacy enable EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show legacy Legacy: enable
