Use the aplist command to modify the list of the Wireless APs that are part of the ExtremeLocation™ support. Use the no form of the command to delete the Wireless APs from the list. The aplist command is accessible from the elocation context of the CLI:
After you run the aplist command, run the apply command to implement the change.
add | delete | Add or delete APs from the list of APs associated with ExtremeLocation support. |
serial[, serial]* | Specifies the Wireless AP, by their serial numbers, that are to be added to the ExtremeLocation support. They can be added or deleted individually, or listed as a comma and space separated list. |
