Use the iot-ibeacon-scan-dest-ip command to configure the customer Application Server's IP address. The iot-ibeacon-scan-dest-ip command is accessible from within the ap:<serial> context of the CLI.
IP Address | Configures the IP address of the customer's Application Server that receives iBeacon scan reports from the ExtremeWireless AP. The report contains the following information: signal strength of the reporting AP, signal strength of the iBeacon tag, MAC address of the iBeacon tag, the iBeacon tag's UUID, Major, and Minor values. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin and iot-application ibeacon-scan before issuing this command.
The following example configures the ibeacon-scan-dest-ip address on an AP3912i:
EWC.extremenetworks.com:ap:3912000000000000#iot-ibeacon-scan-dest-ip 10.233.84.201
