Use the radio1-loadcontrol command to enable or disable load control (soft load limits) on Radio1 only. The radio1-loadcontrol command is accessible from the site:<named-site> context.
Radio Load Control activates only when the number of clients on the radio reaches the configured limit, and does not disconnect any clients already connected. This is the default and preferred mode of load control. Load control can be enabled on one radio and disabled on the other. Members of a WLAN (Wireless Local Area Network) load control group are assigned to both radios and cannot be load controlled individually.
(enable | disable) | Enables or disables the load control function on Radio1. |
The following example enables load control on Radio1:
EWC.extremenetworks.com:site:site1# radio1-loadcontrol enable
