Use the aplist command to add or remove an AP to or from a specific WLAN (Wireless Local Area Network) service configuration. The aplist command is accessible from the wlan:<WLAN-service-name> context of the CLI when the WLAN service type is standard.
After you run the aplist command, run the apply command to implement the changes.
For AP3916, the camera always connects to p1.
The AP3912 offers three client ports and an IoT port:
ap-name | Specifies the name of the AP to add or remove from the WLAN service. The no form of the command removes the AP |
radio1 | radio2 | both | Specifies to use radio1, radio2, or both with the specific WLAN service |
Supported on the AP3912: | |
p1 | p2 | p3 | Specifies the port to configure for the WLAN service. |
Supported on the AP3916: | |
p1 | The camera on the AP3916 always connects to p1. |
Supported on the AP391x: | |
iot | Specifies the IoT port on the AP391x models. |
This command is only available when the WLAN service type is STD.
The following example adds an AP3912i by AP name to the WLAN service named “test” and then displays the list of Wireless APs with port assignments:
EWC.extremenetworks.com:wlans:test# aplist AP3912 radio1 p1 p2 p3 iot
EWC.extremenetworks.com:wlans:test# apply
EWC.extremenetworks.com:wlans:test# show aplist
EWC.extremenetworks.com:wlans:v1WLAN# aplist 3916ic p1
