Use the fast-failover command in the vnsmode:<named-VNS> context to enable or disable the sending of interim account records (to the RADIUS (Remote Authentication Dial In User Service) server) when a failover occurs and the session home moves to the availability partner.
After you run the fast-failover command, run the apply command to implement the changes.
enable | Enables the sending of interim account records to RADIUS for fast failover. |
disable | Disables the sending of interim account records to RADIUS for fast failover. |
This command is available only when this controller has been enabled for fast-failover (see the wlans:<WLAN-service-name>:auth RADIUS server configuration context fast-failover command.
This example disables fast failover:
EWC.extremenetworks.com:vnsmode:VNS1# fast-failover disable EWC.extremenetworks.com:vnsmode:VNS1# apply
