appl-visibility
Use the
appl-visibility command to enable
ExtremeWireless application visibility. With the
ExtremeWireless Application Visibility feature, you can view the following
information:
- IPv4 and IPv6 Addresses
- Host Name
- Operating System
- Device Type
- Top 5 Application Groups by Throughput (2-minute interval)
- Top 5 current Application Groups by Bytes, from session start.
- Throughput chart for an application group.
- Average TCP Round Trip Time.
- Average DNS Round Trip Time.
The appl-visibility
command is accessible from within the
root:wlans:<named-wlan> context.
appl-visibility enable | disable
Parameters
enable |
disable |
Enables or disables the ExtremeWireless Application
Visibility feature. |
The
following example enables application visibility on the specified WLANS.
EWC.extremenetworks.comwlans:<WLAN-service-name>#appl-visibility enable
