Use the vsa-topology command to include topology information in the message to the RADIUS (Remote Authentication Dial In User Service) server. The vsa-topology command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run the vsa-topology command, run the apply command to implement the changes.
enable | disable | Specifies to enable or disable the inclusion of Topology information in messages to the RADIUS server. |
The vsa-topology command is not available when the authentication mode is guestportal. When the authentication mode is disabled, MAC must be enabled for this command to be available. For more information, see mode.
The following example enables the inclusion of Topology information in messages to the RADIUS server:
EWC.extremenetworks.com:wlans:test:auth# vsa-topology enable EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show vsa-topology Topology as VSA attribute: enable
